Saltar al contenido principal
Toshiba Satellite S55T-B5335 Touchpad Replacement
Qué necesitas
  1. Toshiba Satellite S55T-B5335 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 2, imagen 1 de 3 Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 2, imagen 2 de 3 Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 2, imagen 3 de 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: paso 3, imagen 1 de 2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 4, imagen 1 de 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 5, imagen 1 de 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: paso 6, imagen 1 de 2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: paso 6, imagen 2 de 2
    • Using a spudger, lift the black tab that holds the touchpad ribbon cable in place.
    • Using tweezers, pull gently on the purple tab to separate the ribbon cable from the connector.
  7. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 7, imagen 1 de 2 Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 7, imagen 2 de 2
    • Gently push the back side of the touchpad in order to create a gap on the top side of the touchpad.
  8. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 8, imagen 1 de 2 Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, hold the touchpad up in the position from step 2.
    • While the touchpad is held up, use a spudger to scrape loose the adhesive holding the touchpad to the base.
  9. Toshiba Satellite S55T-B5335 Touchpad Replacement: paso 9, imagen 1 de 1
    • Once the adhesive is separated enough from the touchpad, peel it back and remove it.
Conclusión
Equipo
USF Tampa, Team 2-1, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,479
