Introducción
This guide demonstrates how to replace the RAM on Toshiba Satellite S50-B. You will need the Phillips #0 screwdriver and a plastic opening tool.
Qué necesitas
Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
Unscrew all 6.5mm screws on the bottom of the laptop using a Phillips #0 Screwdriver
Using the plastic opening tools, open the back cover and remove it from the laptop.
3 personas más completaron esta guía.
