Saltar al contenido principal
Toshiba Satellite S50-B Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite S50-B Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Hard Drive Replacement: paso 2, imagen 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement: paso 2, imagen 2 de 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 Toshiba Satellite S50-B Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
    • Use a plastic opening tool to remove bottom casing.
  4. Toshiba Satellite S50-B Hard Drive Replacement: paso 4, imagen 1 de 2 Toshiba Satellite S50-B Hard Drive Replacement: paso 4, imagen 2 de 2
    • Use the plastic casing over the hard drive to lift the hard drive up.
    • Once hard drive is slightly lifted up, make sure the laptop is in correct orientation with the battery away from you, and pull the hard drive towards right.
Conclusión
4 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 30
Todo El Tiempo: 6,066
