Saltar al contenido principal
Toshiba Satellite S50-B Cooling Fan Replacement
Qué necesitas
  1. Toshiba Satellite S50-B Cooling Fan Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite S50-B Cooling Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure you turn off the laptop first.
    • Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
  2. Toshiba Satellite S50-B Cooling Fan Replacement: paso 2, imagen 1 de 2 Toshiba Satellite S50-B Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Place thumbs on corners of the battery. Pinch the battery between the thumb and index finger and pull.
  3. Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: paso 3, imagen 1 de 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: paso 3, imagen 2 de 3 Toshiba Satellite S50-B Cooling Fan Replacement, Cooling Fan: paso 3, imagen 3 de 3
    • Locate the 10 screws on the bottom of the device, there should be 12 screws in total including the battery screws. Unscrew using a Phillips #0 screwdriver, and set screws aside.
    • Use a plastic opening tool to remove the bottom panel.
  4. Toshiba Satellite S50-B Cooling Fan Replacement: paso 4, imagen 1 de 3 Toshiba Satellite S50-B Cooling Fan Replacement: paso 4, imagen 2 de 3 Toshiba Satellite S50-B Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Locate the 2 screws on each fan. Unscrew them.
    • Disconnect the fan by applying gentle pressure to the circled connection with your finger and pulling.
    • Remove the fans. Be sure to keep track of the right and left fans, marked R and L.
Conclusión
Una persona más ha completado esta guía.
diana calvo
Miembro Desde 10/17/17
144 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 1,492
