Saltar al contenido principal
Toshiba Satellite Radius P55W-B5220 Battery Replacement
Qué necesitas
  1. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Battery Replacement: paso 3, imagen 1 de 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Battery Replacement: paso 4, imagen 1 de 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
  5. Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: paso 5, imagen 1 de 2 Toshiba Satellite Radius P55W-B5220 Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four M2x2.5mm P0 Philips head screws.
  6. Toshiba Satellite Radius P55W-B5220 Battery Replacement: paso 6, imagen 1 de 2 Toshiba Satellite Radius P55W-B5220 Battery Replacement: paso 6, imagen 2 de 2
    • Pinch the attached cables and carefully pull away to remove the battery.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 2,773
