Saltar al contenido principal
Toshiba Satellite P855-S5312 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: paso 2, imagen 2 de 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: paso 2, imagen 3 de 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Conclusión
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
Miembro Desde 10/02/17
215 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S10-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 1,209
