Saltar al contenido principal
Toshiba Satellite P855-S5312 Fan Replacement
Qué necesitas
  1. Toshiba Satellite P855-S5312 Fan Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Battery: paso 1, imagen 3 de 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: paso 2, imagen 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: paso 2, imagen 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Keyboard: paso 2, imagen 3 de 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
  3. Toshiba Satellite P855-S5312 Fan Replacement, Fan: paso 3, imagen 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: paso 3, imagen 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement, Fan: paso 3, imagen 3 de 3
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  4. Toshiba Satellite P855-S5312 Fan Replacement: paso 4, imagen 1 de 2 Toshiba Satellite P855-S5312 Fan Replacement: paso 4, imagen 2 de 2
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  5. Toshiba Satellite P855-S5312 Fan Replacement: paso 5, imagen 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement: paso 5, imagen 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement: paso 5, imagen 3 de 3
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  6. Toshiba Satellite P855-S5312 Fan Replacement: paso 6, imagen 1 de 2 Toshiba Satellite P855-S5312 Fan Replacement: paso 6, imagen 2 de 2
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  7. Toshiba Satellite P855-S5312 Fan Replacement: paso 7, imagen 1 de 3 Toshiba Satellite P855-S5312 Fan Replacement: paso 7, imagen 2 de 3 Toshiba Satellite P855-S5312 Fan Replacement: paso 7, imagen 3 de 3
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
Conclusión
Dalton
Miembro Desde 10/02/17
215 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S10-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 561
