Saltar al contenido principal
Toshiba Satellite P855-S5312 Disk Drive Replacement
Qué necesitas
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: paso 2, imagen 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: paso 2, imagen 2 de 2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 3, imagen 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 3, imagen 2 de 2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 4, imagen 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 4, imagen 2 de 2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 5, imagen 2 de 2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 6, imagen 1 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 6, imagen 2 de 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: paso 6, imagen 3 de 3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Conclusión
Bishop Clark
Miembro Desde 10/02/17
225 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S10-G2, Thompson Fall 2017 Miembro de USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 470
