Saltar al contenido principal
Toshiba Satellite P855-S5102 Laptop Screen Replacement
Qué necesitas
  1. Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: paso 1, imagen 1 de 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement, Laptop Screen: paso 1, imagen 2 de 2
    • Remove the two F3 screws on the bottom part of the screen.
  2. Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 2, imagen 1 de 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 2, imagen 2 de 2
    • Using a plastic opening tool, carefully pry open the border of the screen away from the screen until the border is completely off.
  3. Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 3, imagen 1 de 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 3, imagen 2 de 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 3, imagen 3 de 3
    • Using the Phillips 001, carefully remove each F3 screw on each corner of the screen.
  4. Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 4, imagen 1 de 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 4, imagen 2 de 3 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 4, imagen 3 de 3
    • Using the Phillips 012, remove the three F2 screws on each side of the screen.
  5. Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 5, imagen 2 de 2
    • Carefully lift up the screen for an easier removal of the webcam. Then gently remove the connector by sliding it out of the webcam.
  6. Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 6, imagen 1 de 2 Toshiba Satellite P855-S5102 Laptop Screen Replacement: paso 6, imagen 2 de 2
    • Remove the tape holding the sliding connector and gently pull it out.
Conclusión
Rodrigo
Miembro Desde 01/25/18
133 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S20-G3, Passmore Spring 2018 Miembro de USF Tampa, Team S20-G3, Passmore Spring 2018
USFT-PASSMORE-S18S20G3
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 269
