Saltar al contenido principal
Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement
Qué necesitas
  1. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Battery: paso 1, imagen 1 de 1
    • First flip the device over so that the back side is facing upwards
  2. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 2, imagen 1 de 1
    • Push the two sliders toward the edge of the laptop.
    • Remove the battery.
  3. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement, Display Assembly: paso 3, imagen 1 de 1
    • Open the lid.
  4. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 4, imagen 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 4, imagen 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the four screw covers in each of the four corners of the screen.
  5. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 5, imagen 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 5, imagen 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 5, imagen 3 de 3
    • Remove the 4 screws in each of the 4 corners.
  6. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 6, imagen 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 6, imagen 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 6, imagen 3 de 3
    • Take your prying tool and proceed to pry the screen cover off and set to the side.
  7. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 7, imagen 1 de 1
    • Disconnect the wire from the camera and the backside of the display assembly.
  8. Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 8, imagen 1 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 8, imagen 2 de 3 Toshiba Satellite P755-EZ1511D Laptop Display Assembly Replacement: paso 8, imagen 3 de 3
    • Remove the 6 screws holding the display assembly and holding brackets together.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 73
