Saltar al contenido principal
Toshiba Satellite P75-A7100 Fan Replacement
Qué necesitas
  1. Toshiba Satellite P75-A7100 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the tabs apart from each other.
  2. Toshiba Satellite P75-A7100 Fan Replacement: paso 2, imagen 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement: paso 2, imagen 2 de 2
    • Lift the battery upwards and remove it from the device.
  3. Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: paso 3, imagen 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement, Wi-Fi Adapter: paso 3, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the screw from the back cover.
    • Remove the back cover from the device.
  4. Toshiba Satellite P75-A7100 Fan Replacement: paso 4, imagen 1 de 3 Toshiba Satellite P75-A7100 Fan Replacement: paso 4, imagen 2 de 3 Toshiba Satellite P75-A7100 Fan Replacement: paso 4, imagen 3 de 3
    • Remove the optical drive from the device.
  5. Toshiba Satellite P75-A7100 Fan Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the remaining screws that are visible on the laptop.
    • Remove the back cover from your device.
  6. Toshiba Satellite P75-A7100 Fan Replacement: paso 6, imagen 1 de 3 Toshiba Satellite P75-A7100 Fan Replacement: paso 6, imagen 2 de 3 Toshiba Satellite P75-A7100 Fan Replacement: paso 6, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the screw connecting the Wi-Fi adapter to the motherboard.
    • Remove the Wi-Fi adapter from the device.
  7. Toshiba Satellite P75-A7100 Fan Replacement, Fan: paso 7, imagen 1 de 2 Toshiba Satellite P75-A7100 Fan Replacement, Fan: paso 7, imagen 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
    • Unplug the connector connecting the fan to the motherboard.
    • Remove the fan from the device.
Conclusión
2 personas más completaron esta guía.
Un comentario
How do you remove and replace the fan from from/to the heatsink? Mine is secured with a metallic tape that is not sticky once removed.
Bruce - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 2,305
