Saltar al contenido principal
Toshiba Satellite P55t-A5116 Power Jack Replacement
Qué necesitas
  1. Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: paso 1, imagen 1 de 2 Toshiba Satellite P55t-A5116 Power Jack Replacement, Back Casing: paso 1, imagen 2 de 2
    • Close laptop and turn it upside down
    • Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
  2. Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 2, imagen 1 de 2 Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 2, imagen 2 de 2
    • Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
  3. Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 3, imagen 1 de 3 Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 3, imagen 2 de 3 Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 3, imagen 3 de 3
    • Gently pry off the bottom case with the plastic opening tools.
    • Find the seam between the back case and the rest of the laptop casing.
  4. Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: paso 4, imagen 1 de 2 Toshiba Satellite P55t-A5116 Power Jack Replacement, Battery: paso 4, imagen 2 de 2
    • Use the #PH0 screw head, remove 4 (5.7mm) screws.
    • Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
  5. Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 5, imagen 1 de 1
    • Gently remove battery from the laptop.
  6. Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: paso 6, imagen 1 de 3 Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: paso 6, imagen 2 de 3 Toshiba Satellite P55t-A5116 Power Jack Replacement, Power Jack: paso 6, imagen 3 de 3
    • Using the #PH0 screw head, remove 2 (5.7 mm) screws.
    • Remove metal plate.
    • Using the #PH0 screw head remove 1 (5.7mm) screw and 1 (4.15mm) screw.
  7. Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 7, imagen 1 de 2 Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 7, imagen 2 de 2
    • Use the plastic opening tool to push the left hinge up.
  8. Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 8, imagen 1 de 2 Toshiba Satellite P55t-A5116 Power Jack Replacement: paso 8, imagen 2 de 2
    • Gently pull up the power jack. Follow the cord until you reach the connector.
    • Unplug the 4 pin connector and remove from laptop
Conclusión
2 personas más completaron esta guía.
Un comentario
Absolutely terrific tutorial! This helped me immensely. My laptop is Toshiba Satellite P55T-5202 and has the same layout as this. This worked perfectly.
I purchased the part form Amazon, btw. Its a DC Power Jack Replacement
Alampana - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,777
