Saltar al contenido principal
Toshiba Satellite P55W-C5316 Back Panel Replacement
Qué necesitas
  1. Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 2 Toshiba Satellite P55W-C5316 Back Panel Replacement, Back Panel: paso 1, imagen 2 de 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 Back Panel Replacement: paso 2, imagen 1 de 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: paso 2, imagen 2 de 3 Toshiba Satellite P55W-C5316 Back Panel Replacement: paso 2, imagen 3 de 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
Conclusión
Nicholas Caswell
Miembro Desde 10/19/17
117 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 950
