Saltar al contenido principal
Toshiba Satellite P55W-C5200X Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 2, imagen 1 de 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 3, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 3, imagen 2 de 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 4, imagen 2 de 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 5, imagen 2 de 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: paso 6, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: paso 6, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: paso 6, imagen 3 de 3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: paso 7, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: paso 7, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: paso 7, imagen 3 de 3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 8, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 8, imagen 2 de 2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 9, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 9, imagen 2 de 2
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: paso 10, imagen 1 de 1
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 11, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 11, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 11, imagen 3 de 3
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 12, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 12, imagen 2 de 2
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 13, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 13, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 13, imagen 3 de 3
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 14, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 14, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 14, imagen 3 de 3
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 15, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 15, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 15, imagen 3 de 3
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 16, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 16, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 16, imagen 3 de 3
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 17, imagen 1 de 2 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 17, imagen 2 de 2
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 18, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 18, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 18, imagen 3 de 3
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 19, imagen 1 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 19, imagen 2 de 3 Toshiba Satellite P55W-C5200X Keyboard Replacement: paso 19, imagen 3 de 3
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Miembro de UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,326
