Saltar al contenido principal
Toshiba Satellite P55-A5312 Battery Replacement
Qué necesitas
  1. Toshiba Satellite P55-A5312 Battery Replacement, Battery: paso 1, imagen 1 de 2 Toshiba Satellite P55-A5312 Battery Replacement, Battery: paso 1, imagen 2 de 2
  2. Toshiba Satellite P55-A5312 Battery Replacement: paso 2, imagen 1 de 2 Toshiba Satellite P55-A5312 Battery Replacement: paso 2, imagen 2 de 2
    • Locate the battery, which is in the top right hand corner of the laptop.
    • Remove all the 2.5x6mm screws that secure the battery with a Philips 00 screwdriver.
  3. Toshiba Satellite P55-A5312 Battery Replacement: paso 3, imagen 1 de 1
    • Locate the intersection of the wires that connect the battery to the motherboard.
    • Unplug these wires by gently pulling on the white plug, as shown in the picture.
  4. Toshiba Satellite P55-A5312 Battery Replacement: paso 4, imagen 1 de 1
    • Carefully remove the speaker that is placed above the battery by gently pulling upward from one end. Be careful not to break a wire.
    • Move the speaker elsewhere while replacing the battery (do not disconnect it).
  5. Toshiba Satellite P55-A5312 Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the laptop after it has been completely disconnected.
Conclusión
5 personas más completaron esta guía.
ohatae
Miembro Desde 01/25/17
294 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 9-1, Banghart Winter 2017 Miembro de Cal Poly, Team 9-1, Banghart Winter 2017
CPSU-BANGHART-W17S9G1
3 Miembros
6 Guías creadas
Un comentario
The repair guide was great. Got right through the battery change procedure. only took about 25 minutes start to finish. I was told by a friend to try this as a way to bypass the forgotten password at startup of the computer so that I could put a new password in it. The result is that did not work. Can anybody tell me how to do this
Roy Conrad - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 5,866
