Saltar al contenido principal
Toshiba Satellite P50W-C Mother Board Replacement
Qué necesitas
  1. Toshiba Satellite P50W-C Mother Board Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Mother Board Replacement: paso 2, imagen 1 de 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Mother Board Replacement: paso 3, imagen 1 de 2 Toshiba Satellite P50W-C Mother Board Replacement: paso 3, imagen 2 de 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: paso 4, imagen 1 de 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: paso 4, imagen 2 de 3 Toshiba Satellite P50W-C Mother Board Replacement, Mother Board: paso 4, imagen 3 de 3
    • Remove all power connections to the motherboard. Including the black and white power connections to the wifi module.
  5. Toshiba Satellite P50W-C Mother Board Replacement: paso 5, imagen 1 de 3 Toshiba Satellite P50W-C Mother Board Replacement: paso 5, imagen 2 de 3 Toshiba Satellite P50W-C Mother Board Replacement: paso 5, imagen 3 de 3
    • Unscrew the two 7 mm JIS head screws in the fan .
    • Then unscrew the four 2 mm JIS head screws connecting the heat sink to the mother board.
    • Then take out the heat sink and fan.
  6. Toshiba Satellite P50W-C Mother Board Replacement: paso 6, imagen 1 de 1
    • Remove both 3mm JIS head screws connecting the motherboard to the device.
  7. Toshiba Satellite P50W-C Mother Board Replacement: paso 7, imagen 1 de 1
    • Remove 5mm silver Phillips head screw connecting black cover to the motherboard
  8. Toshiba Satellite P50W-C Mother Board Replacement: paso 8, imagen 1 de 2 Toshiba Satellite P50W-C Mother Board Replacement: paso 8, imagen 2 de 2
    • Remove all three 5 mm silver JIS head screws connecting the silver cover to the motherboard.
  9. Toshiba Satellite P50W-C Mother Board Replacement: paso 9, imagen 1 de 1
    • You can now gently remove the motherboard from the device.
Conclusión
Brittany Edwards
Miembro Desde 09/25/17
104 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S3-G2, Cannon Fall 2017 Miembro de USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 468
