Saltar al contenido principal
Toshiba Satellite P50W-C Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite P50W-C Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Hard Drive Replacement: paso 3, imagen 1 de 2 Toshiba Satellite P50W-C Hard Drive Replacement: paso 3, imagen 2 de 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 1
    • Remove the back cover of the device.
  5. Toshiba Satellite P50W-C Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive from the device by gently pulling on the blue plastic hard drive cover.
  6. Toshiba Satellite P50W-C Hard Drive Replacement: paso 6, imagen 1 de 2 Toshiba Satellite P50W-C Hard Drive Replacement: paso 6, imagen 2 de 2
    • Disconnect the hard drive from the mother board by gently pulling out the black connector.
Conclusión
2 personas más completaron esta guía.
Sarah Fordjour
Miembro Desde 09/25/17
450 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S3-G2, Cannon Fall 2017 Miembro de USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Miembros
7 Guías creadas
Un comentario
Can you change the touch panel of toshibasatelliteP50W-B1038.
rizwana rizi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 10
Todo El Tiempo: 645
