Saltar al contenido principal
Toshiba Satellite P205D-S8804 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 2, imagen 1 de 1
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 3, imagen 1 de 1
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 4, imagen 1 de 1
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 5, imagen 2 de 2
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: paso 6, imagen 1 de 1
    • Once the ribbon is released the keyboard can be removed .
Conclusión
Caroline Camp
Miembro Desde 01/30/17
1 Reputación
3 Guías creadas
Equipo
Baylor, Team 3-2, Whitney Spring 2017 Miembro de Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Miembros
4 Guías creadas
Un comentario
rename tool with a standard link for easier accessibility
Andy Feng - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 198
