Introducción
This guide will take you through the steps to remove the RAM from the laptop for replacement. You can use this guide to replace malfunctioning RAM chips or to replace your older RAM chips with newer or better chips.
Qué necesitas
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
