Saltar al contenido principal
Toshiba Satellite P105-S6147 Screen Replacement
  1. Toshiba Satellite P105-S6147 Screen Replacement, Keyboard: paso 1, imagen 1 de 1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Screen Replacement: paso 2, imagen 1 de 1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Screen Replacement: paso 3, imagen 1 de 2 Toshiba Satellite P105-S6147 Screen Replacement: paso 3, imagen 2 de 2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Screen Replacement: paso 4, imagen 1 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 4, imagen 2 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 4, imagen 3 de 3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Screen Replacement: paso 5, imagen 1 de 2 Toshiba Satellite P105-S6147 Screen Replacement: paso 5, imagen 2 de 2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
  6. Toshiba Satellite P105-S6147 Screen Replacement, Screen: paso 6, imagen 1 de 2 Toshiba Satellite P105-S6147 Screen Replacement, Screen: paso 6, imagen 2 de 2
    • Use the Phillips #0 screwdriver to unscrew the four 3 mm screws connecting the screen to the keyboard.
  7. Toshiba Satellite P105-S6147 Screen Replacement: paso 7, imagen 1 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 7, imagen 2 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 7, imagen 3 de 3
    • Disconnect the white cord that is connected from the screen to the keyboard.
    • Disconnect the cord from the bottom of the keyboard.
    • Gently pull the cord out from the fastening clips on the keyboard.
  8. Toshiba Satellite P105-S6147 Screen Replacement: paso 8, imagen 1 de 2 Toshiba Satellite P105-S6147 Screen Replacement: paso 8, imagen 2 de 2
    • Remove the rubber pads from the four corners of the screen, revealing four screws.
  9. Toshiba Satellite P105-S6147 Screen Replacement: paso 9, imagen 1 de 1
    • Remove the plastic bevel from around the screen.
    • Pull the bevel up and off.
  10. Toshiba Satellite P105-S6147 Screen Replacement: paso 10, imagen 1 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 10, imagen 2 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 10, imagen 3 de 3
    • Use the Phillips #0 screwdriver to remove the 4 mm screws located on the top of the screen and the sides.
  11. Toshiba Satellite P105-S6147 Screen Replacement: paso 11, imagen 1 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 11, imagen 2 de 3 Toshiba Satellite P105-S6147 Screen Replacement: paso 11, imagen 3 de 3
    • Remove the 2 white plugins from the bottom of the screen.
    • Pull gently on the white plugs to remove them.
  12. Toshiba Satellite P105-S6147 Screen Replacement: paso 12, imagen 1 de 1
    • Pull the screen out of the laptop cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 344
