Saltar al contenido principal
Toshiba Satellite M55-S135 Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: paso 3, imagen 1 de 1
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: paso 5, imagen 1 de 2 Toshiba Satellite M55-S135 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: paso 6, imagen 1 de 1
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
Conclusión
2 personas más completaron esta guía.
Matthew Trinh
Miembro Desde 01/31/13
63 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 7-11, Maness Winter 2013 Miembro de Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Miembros
5 Guías creadas
2 comentarios
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - Contestar
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 3,941
