Saltar al contenido principal
Introducción
Learn to replace your wifi card.
Partes
No se especificaron partes.
  1. Remove the panel screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards. Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
    • Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
    • The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
    • Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 4,389
