Saltar al contenido principal
Toshiba Satellite M45 Speakers Replacement
Qué necesitas
  1. Toshiba Satellite M45 Speakers Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure device is off and power supply is disconnected.
    • Flip the laptop to the bottom side.
    • Locate and slide the two battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Toshiba Satellite M45 Speakers Replacement, RAM: paso 2, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, RAM: paso 2, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, RAM: paso 2, imagen 3 de 3
    • Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
    • Then, use a the blue iFixit Opening Tool to pry the cover panel off.
    • Push on to the RAM tabs to disconnect the RAM form the device.
    • The RAM will pop off from the socket. Gently pull the RAM out of the socket.
  3. Toshiba Satellite M45 Speakers Replacement, Wi-Fi Card: paso 3, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Wi-Fi Card: paso 3, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Wi-Fi Card: paso 3, imagen 3 de 3
    • Use the #1 Phillips head screwdriver to unscrew the panel.
    • Disconnect the black and white wires.
    • Push on the tabs to disconnect the Wi-Fi card.
    • Use the blue iFixit Opening Tool to pull the Wi-Fi Card out.
  4. Toshiba Satellite M45 Speakers Replacement, Hard Drive: paso 4, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Hard Drive: paso 4, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Use the #1 Phillips head screwdriver as to remove the hard drive screw.
    • Use the blue iFixit Opening Tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Toshiba Satellite M45 Speakers Replacement, Optical Drive: paso 5, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Optical Drive: paso 5, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Optical Drive: paso 5, imagen 3 de 3
    • Use the #1 Phillips head screwdriver remove the Optical Drive screw.
    • Use the blue iFixit Opening Tool to pry the Optical Drive out of the slot from the side of the casing.
    • Use your hands to pull the rest of the Optical Drive out.
  6. Toshiba Satellite M45 Speakers Replacement, Keyboard: paso 6, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Keyboard: paso 6, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Keyboard: paso 6, imagen 3 de 3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  7. Toshiba Satellite M45 Speakers Replacement: paso 7, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement: paso 7, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement: paso 7, imagen 3 de 3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  8. Toshiba Satellite M45 Speakers Replacement, Motherboard: paso 8, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Motherboard: paso 8, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Motherboard: paso 8, imagen 3 de 3
    • Disconnect the video cable, then slowly and firmly pull the video cable upwards.
    • Disconnect the brown ribbon located in the middle area of the laptop.
    • Disconnect the two white ribbons located in the bottom left of the laptop.
    • Firmly pull out the two white ribbons.
  9. Toshiba Satellite M45 Speakers Replacement: paso 9, imagen 1 de 2 Toshiba Satellite M45 Speakers Replacement: paso 9, imagen 2 de 2
    • Use the Phillips #00 Screwdriver to unscrew all the screws.
    • Unscrew three additional screws through the three holes on the optical drive.
  10. Toshiba Satellite M45 Speakers Replacement: paso 10, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement: paso 10, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement: paso 10, imagen 3 de 3
    • Turn the laptop upside down.
    • Use the blue iFixit Opening Tool to slowly pry the case upward.
    • Remove the white ribbon
    • Make sure to completely remove the white ribbon and set it to the right side of the motherboard. and not on top of the motherboard.
  11. Toshiba Satellite M45 Speakers Replacement: paso 11, imagen 1 de 2 Toshiba Satellite M45 Speakers Replacement: paso 11, imagen 2 de 2
    • Lift up the motherboard.
    • Be careful not to rip out small components on the motherboard. Carefully remove the motherboard.
  12. Toshiba Satellite M45 Speakers Replacement, Speakers: paso 12, imagen 1 de 3 Toshiba Satellite M45 Speakers Replacement, Speakers: paso 12, imagen 2 de 3 Toshiba Satellite M45 Speakers Replacement, Speakers: paso 12, imagen 3 de 3
    • Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
    • Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
  13. Toshiba Satellite M45 Speakers Replacement: paso 13, imagen 1 de 2 Toshiba Satellite M45 Speakers Replacement: paso 13, imagen 2 de 2
    • To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise.
    • Reverse the order after installing the new speakers.
Conclusión
Stephen
Miembro Desde 04/20/10
370 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 10-42, Garner Spring 2010 Miembro de Cal Poly, Team 10-42, Garner Spring 2010
CPSU-GARNER-S10S10G42
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 6,151
