Saltar al contenido principal
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: paso 1, imagen 1 de 2 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: paso 1, imagen 2 de 2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: paso 2, imagen 1 de 2 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: paso 2, imagen 2 de 2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: paso 3, imagen 1 de 2 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: paso 3, imagen 2 de 2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
Conclusión
Nathan Jansen
Miembro Desde 09/08/14
206 Reputación
1 Guía escrita
Equipo
CSU Fullerton, Team 2-4, Bruce Fall 2014 Miembro de CSU Fullerton, Team 2-4, Bruce Fall 2014
CSUF-BRUCE-F14S2G4
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 357
