1. Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Locate the two clips holding the RAM chip in place.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
    • Gently pull RAM out as shown.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
Conclusión
Equipo
Cal Poly, Team 4-3, Regan Spring 2011 Miembro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 2,553
