Saltar al contenido principal
Toshiba Satellite M305D-S4829 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 4, imagen 1 de 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 4, imagen 2 de 2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 5, imagen 1 de 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 5, imagen 2 de 2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 6, imagen 1 de 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 6, imagen 2 de 2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 7, imagen 1 de 2 Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 7, imagen 2 de 2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: paso 8, imagen 1 de 1
    • Your keyboard has now been successfully removed.
Conclusión
2 personas más completaron esta guía.
Equipo
Cal Poly, Team 4-3, Regan Spring 2011 Miembro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 4,550
