1. Unlatch the battery by pushing outward on both latches.
    • Unlatch the battery by pushing outward on both latches.
  2. Slide battery out.
    • Slide battery out.
  3. Remove the five "F2" screws with a Phillips #0 screwdriver.
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Insert the plastic opening tool above the F1 key. Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Find the screws above the F1 and INS keys. Unscrew both screws with a Phillips #0 screwdriver.
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Slowly lift the top edge of the keyboard out with your fingers. The ribbon cable located on the back of the keyboard will become accessible.
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Locate the black ribbon cable flap. Detach flap with plastic opening tool.  The ribbon cable will become free.
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Your keyboard has now been successfully removed.
    • Your keyboard has now been successfully removed.
  9. Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  10. Locate and remove the circled screw with a Phillips #0 screwdriver. Locate and remove the circled screw with a Phillips #0 screwdriver.
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  11. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  12. Use the plastic opening tool to pry the CD/DVD drive out of the frame.
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  13. Gently remove the CD/DVD drive from the laptop body.
    • Gently remove the CD/DVD drive from the laptop body.
  14. Remove the circled screws with Phillips #0 screwdriver. Remove the circled screws with Phillips #0 screwdriver.
    • Remove the circled screws with Phillips #0 screwdriver.
  15. Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
    • Remove these screws from the underside of the laptop with Phillips #0 screwdriver.
  16. Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
    • Disconnect the three circled antennas by lightly pulling upward with your fingers. They should detach easily.
    • Note: Yours may only have two (2) antennas. Pay attention to the Orientation of the Aluminum bracket with the pads for reinstallation.
  17. Remove the circled screw with a Phillips #0 screwdriver.
    • Remove the circled screw with a Phillips #0 screwdriver.
  18. Detach the 3 marked cables by pulling them out with you fingers as shown.
    • Detach the 3 marked cables by pulling them out with you fingers as shown.
    • This may require some force. They do not come out easily.
  19. Detach the four blue ribbon cables carefully with tweezers. Some of the ribbons may require a flap to be raised because it secures the ribbon in.
    • Detach the four blue ribbon cables carefully with tweezers. Some of the ribbons may require a flap to be raised because it secures the ribbon in.
  20. Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
    • Remove the top plastic cover by lifting upward from the bottom left-hand corner as shown. The cover will come off easily.
  21. Remove the circled motherboard screws with a Phillips #0 Scewdriver.
    • Remove the circled motherboard screws with a Phillips #0 Scewdriver.
    • Disconnect this ribbon cable.
  22. Remove these screws with a Phillips #0 screwdriver.
    • Remove these screws with a Phillips #0 screwdriver.
  23. Detach the display cable by gently pulling it out with your fingers.
    • Detach the display cable by gently pulling it out with your fingers.
  24. Remove the motherboard from the left side by gently lifting the left side upward. The boxed volume control may snag on the laptop frame when pulling the motherboard out.
    • Remove the motherboard from the left side by gently lifting the left side upward.
    • The boxed volume control may snag on the laptop frame when pulling the motherboard out.
  25. The motherboard has now been removed from laptop.
    • The motherboard has now been removed from laptop.
  26. Detach the fan power cord by pulling it out with your fingers.
    • Detach the fan power cord by pulling it out with your fingers.
    • Carefully lift up the tape on the fan by peeling the right edge to the left. It can remain attached to the heatsink but should be removed from the fan.
  27. Remove the circled screws with a Phillips #0 screwdriver.
    • Remove the circled screws with a Phillips #0 screwdriver.
  28. Locate the 3 circled clips holding the fan to the motherboard. Pry each clip outward while applying upward force on the fan as shown. Pry each clip outward while applying upward force on the fan as shown.
    • Locate the 3 circled clips holding the fan to the motherboard.
    • Pry each clip outward while applying upward force on the fan as shown.
  29. Carefully pull out the fan. Note: replacing the fan is highly reccomended
    • Carefully pull out the fan.
    • Note: replacing the fan is highly reccomended
    • Optionally you may clean the fan with Air + Q-Tips. To remove the blade turn the fan over and gently pull the fan blade from the housing.
    • If the fan is no longer operational, it may be possible to temporarily repair it by removing the fan blade and put a small amount of WD-40 on the pinion shaft hole the fan rotates in. A toothpick is a good applicator. Do NOT contaminate the motor area with any of the dust/grime that has accumulated.
    • Insert the fan blade and move the blades with your finger. It should spin freely and cog to a stop. Again this is a temporary fix!
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 4-3, Regan Spring 2011 Miembro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 5,759
