Partes
No se requieren partes.
  1. Unlatch the battery by pushing outward on both latches.
    • Unlatch the battery by pushing outward on both latches.
  2. Slide battery out.
    • Slide battery out.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  5. Locate and remove the circled screw with a Phillips #0 screwdriver. Locate and remove the circled screw with a Phillips #0 screwdriver.
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  6. Use the plastic opening tool to pry the CD/DVD drive out of the frame.
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  7. Gently remove the CD/DVD drive from the laptop body.
    • Gently remove the CD/DVD drive from the laptop body.
Conclusión
Equipo
Cal Poly, Team 4-3, Regan Spring 2011 Miembro de Cal Poly, Team 4-3, Regan Spring 2011
CPSU-REGAN-S11S4G3
5 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 2,799
