Introducción
This guide details removing and replacing the hard drive inside a Toshiba Satellite L855-S5119.
Qué necesitas
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Unscrew the hard drive.
Carefully push the hard drive away from its port. This should not require substantial force.
Lift the hard drive out.
2 personas más completaron esta guía.
