Saltar al contenido principal
Toshiba Satellite L775D-S7340 RAM Replacement
Qué necesitas
  1. Toshiba Satellite L775D-S7340 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 RAM Replacement: paso 3, imagen 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Use the Phillips #1 screwdriver to remove the one 4.6 mm screw holding on the cover located on the bottom center of the laptop.
  5. Toshiba Satellite L775D-S7340 RAM Replacement: paso 5, imagen 1 de 1
    • Use the plastic opening tool to pry open the RAM cover. Wedge the prying tool in, beginning at the indent in the cover.
  6. Toshiba Satellite L775D-S7340 RAM Replacement: paso 6, imagen 1 de 1
    • Use another prying tool to pry up along the edges of the cover. Continue prying up around the edges until the cover is open and remove it.
  7. Toshiba Satellite L775D-S7340 RAM Replacement: paso 7, imagen 1 de 2 Toshiba Satellite L775D-S7340 RAM Replacement: paso 7, imagen 2 de 2
    • Push the two top tabs outwards and the top stick of RAM will pop up. Gently remove the stick of RAM by pulling it out.
  8. Toshiba Satellite L775D-S7340 RAM Replacement: paso 8, imagen 1 de 1
    • Push the two bottom tabs outwards and the bottom stick of RAM will pop up. Gently remove the bottom stick of RAM by pulling it out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 406
