Saltar al contenido principal
Toshiba Satellite L775D-S7340 Optical Disk Drive Replacement
Qué necesitas
  1. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: paso 2, imagen 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: paso 3, imagen 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Optical Disk Drive: paso 4, imagen 1 de 1
    • Remove the (mm) screw in between the two white manufacturer’s stickers using the Phillips #1 screwdriver.
  5. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: paso 5, imagen 1 de 1
    • Gently slide the optical disk drive out of the computer.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 209
