Introducción
This guide will show you how to remove and replace the laptop fan.
Qué necesitas
Make sure the laptop is unplugged and powered off.
Locate the battery latches on the underside of the laptop.
Pry up the thin narrow strip of facing above the keyboard using the opening tool.
Remove the twelve screws from the underside of the laptop using the Philips #1 screwdriver.
3 comentarios
Is the “keyboard” reference in step 11 correct? Wasn’t the “keyboard” removed in step 7?
You are correct. It should say to remove the plastic tray as it does in other manuals for this laptop. Thank you.
I just discovered “IFixit” a couple of days ago. You provide the most clear and useful “How to” that I have seen, either in print or on the Internet. The ability to enlarge the photos is extremely helpful when attempting a repair on an unfamiliar system. The difficulty rating and project time estimate allowed me to decide whether to attempt the replacement myself, or to use the “Geek Squad”. Keep up the good work!
jb
