Saltar al contenido principal
Toshiba Satellite L775D-S7340 Fan Replacement
Qué necesitas
  1. Toshiba Satellite L775D-S7340 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Fan Replacement: paso 2, imagen 1 de 1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Fan Replacement: paso 3, imagen 1 de 1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Fan Replacement, Keyboard: paso 4, imagen 1 de 1
    • Pry up the thin narrow strip of facing above the keyboard using the opening tool.
  5. Toshiba Satellite L775D-S7340 Fan Replacement: paso 5, imagen 1 de 1
    • Remove the four screws securing the keyboard using the T4 Torx screwdriver,
  6. Toshiba Satellite L775D-S7340 Fan Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L775D-S7340 Fan Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard slowly using the opening tool and lean it toward touchpad.
    • It will still be held by the connector ribbon. Make sure not to pull out the connector ribbon.
  7. Toshiba Satellite L775D-S7340 Fan Replacement: paso 7, imagen 1 de 1
    • The ribbon is attached by a white clip. Wedge the white clip up carefully using the spudger. This will release the connector ribbon and you can now remove the keyboard.
  8. Toshiba Satellite L775D-S7340 Fan Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the twelve screws from the underside of the laptop using the Philips #1 screwdriver.
  9. Toshiba Satellite L775D-S7340 Fan Replacement: paso 9, imagen 1 de 1
    • Remove the three screws from the underside of the laptop using a Phillips #1 screwdriver.
  10. Toshiba Satellite L775D-S7340 Fan Replacement: paso 10, imagen 1 de 1
    • Remove the two screws from the underside of the laptop where the battery was located using the Philips #1 screwdriver.
  11. Toshiba Satellite L775D-S7340 Fan Replacement: paso 11, imagen 1 de 1
    • Remove the four screws securing the keyboard using the Philips #1 screwdriver .
  12. Toshiba Satellite L775D-S7340 Fan Replacement: paso 12, imagen 1 de 1
    • Detach the ribbon cable carefully using the spudger to gently pry up on the clip until it releases the ribbon cable or lift up on the blue tab gently until the clip releases the ribbon cable.
  13. Toshiba Satellite L775D-S7340 Fan Replacement: paso 13, imagen 1 de 1
    • Disconnect the wire connector by using the flat end of spudger to gently pry it apart from the connection point.
    • This can also be accomplished by holding the connector and gently wiggling the connector loose.
  14. Toshiba Satellite L775D-S7340 Fan Replacement: paso 14, imagen 1 de 1
    • Remove the top plastic cover by lifting from one of the corners it should be easy to removed.
  15. Toshiba Satellite L775D-S7340 Fan Replacement: paso 15, imagen 1 de 1
    • Remove the two screws securing the fan using the Phillips #1 screwdriver .
  16. Toshiba Satellite L775D-S7340 Fan Replacement: paso 16, imagen 1 de 1
    • Disconnect the fan wire connector using the flat end of spudger to gently pry it apart from the connection point, then remove the fan.
Conclusión
3 comentarios
Is the “keyboard” reference in step 11 correct? Wasn’t the “keyboard” removed in step 7?
J. Barr - Contestar
You are correct. It should say to remove the plastic tray as it does in other manuals for this laptop. Thank you.
Elizabeth Sadewasser -
I just discovered “IFixit” a couple of days ago. You provide the most clear and useful “How to” that I have seen, either in print or on the Internet. The ability to enlarge the photos is extremely helpful when attempting a repair on an unfamiliar system. The difficulty rating and project time estimate allowed me to decide whether to attempt the replacement myself, or to use the “Geek Squad”. Keep up the good work!
jb
J. Barr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 1,222
