Introducción
Usually when people hear that their motherboard needs to be replaced they think that it is the end for their computer. It is something that should be done with care since there are many intricate parts. It's good to have something to put your screws in, too.
Qué necesitas
After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
Slide the ODD outward.
2 personas más completaron esta guía.
