Introducción
Before taking out the keyboard it is good to know that this is the last resort to your problem. Make sure that you are in an area with space because many things will be removed and you do not want to lose them.
Qué necesitas
After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
Replace after you are done with your goal replacement.
Una persona más ha completado esta guía.
