Saltar al contenido principal
Toshiba Satellite L755D-S5150 Battery Removal
  1. Toshiba Satellite L755D-S5150 Battery Removal, Battery: paso 1, imagen 1 de 2 Toshiba Satellite L755D-S5150 Battery Removal, Battery: paso 1, imagen 2 de 2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
Conclusión
2 personas más completaron esta guía.
Kyler Clonts
Miembro Desde 10/06/16
258 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-5, Sullivan Fall 2016 Miembro de USF Tampa, Team 2-5, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G5
4 Miembros
5 Guías creadas
Un comentario
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
Iván Andrade - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 232
