Esta guía ha sufrido modificaciones. Revisa la última versión sin revisar.
Introducción
To replace the Satellite L755 motherboard you will need a Phillips (PH0) screwdriver. The motherboard is fragile and should not be bent or pried away from other parts or forced into place since it may break.
Qué necesitas
Begin by unscrewing the screw located underneath the battery.
Then, unsnap and remove the bar above the keyboard.
Remove the seven 4mm Phillips #0 screws beneath the keyboard.
After the screws are removed, remove the face plate to reveal the motherboard.
Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
Remove the four 4mm Phillips #0 screws under the edge covering flaps.
Carefully lift out the motherboard and fan.
To detach the fan, remove the two 2mm Phillips #0 screws.
Una persona más ha completado esta guía.
