Saltar al contenido principal
Toshiba Satellite L675D-S7016 RAM Replacement
Qué necesitas
  1. Toshiba Satellite L675D-S7016 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 RAM Replacement: paso 2, imagen 1 de 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 RAM Replacement: paso 3, imagen 1 de 3 Toshiba Satellite L675D-S7016 RAM Replacement: paso 3, imagen 2 de 3 Toshiba Satellite L675D-S7016 RAM Replacement: paso 3, imagen 3 de 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 RAM Replacement, Back Panel Removal: paso 4, imagen 1 de 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 RAM Replacement: paso 5, imagen 1 de 2 Toshiba Satellite L675D-S7016 RAM Replacement: paso 5, imagen 2 de 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 RAM Replacement, RAM: paso 6, imagen 1 de 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: paso 6, imagen 2 de 3 Toshiba Satellite L675D-S7016 RAM Replacement, RAM: paso 6, imagen 3 de 3
    • Using your fingers, spread the spring tabs holding the top stick of RAM in place.
    • Once the tabs are spread apart, the stick of RAM will pop up.
    • Remove the first stick of RAM by pulling out along the same angle the RAM stick springs up.
  7. Toshiba Satellite L675D-S7016 RAM Replacement: paso 7, imagen 1 de 3 Toshiba Satellite L675D-S7016 RAM Replacement: paso 7, imagen 2 de 3 Toshiba Satellite L675D-S7016 RAM Replacement: paso 7, imagen 3 de 3
    • Repeat the same procedure to remove the second stick of RAM.
Conclusión
Austin Bons
Miembro Desde 09/22/16
1,131 Reputación
8 Guías creadas
Equipo
UC Davis, Team 2-2, Oliver Fall 2016 Miembro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 588
