Saltar al contenido principal
Toshiba Satellite L675D-S7016 Keyboard Replacement
Qué necesitas
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 3, imagen 1 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 3, imagen 2 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 3, imagen 3 de 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 5, imagen 1 de 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 6, imagen 2 de 2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 7, imagen 1 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 7, imagen 2 de 3 Toshiba Satellite L675D-S7016 Keyboard Replacement: paso 7, imagen 3 de 3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
Conclusión
Una persona más ha completado esta guía.
Austin Bons
Miembro Desde 09/22/16
1,131 Reputación
8 Guías creadas
Equipo
UC Davis, Team 2-2, Oliver Fall 2016 Miembro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 777
