Saltar al contenido principal
Toshiba Satellite L675D-S7016 Hard Drive Replacement
Qué necesitas
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 3, imagen 1 de 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 3, imagen 2 de 3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 3, imagen 3 de 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: paso 4, imagen 1 de 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 5, imagen 1 de 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
Conclusión
To install a new Hard Drive, follow these instructions in reverse order.
2 personas más completaron esta guía.
Austin Bons
Miembro Desde 09/22/16
1,131 Reputación
8 Guías creadas
Equipo
UC Davis, Team 2-2, Oliver Fall 2016 Miembro de UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,028
