Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Locate the battery locks on the bottom of the laptop. Slide the right lock outwards, until it locks into place. Slide and hold the left lock outwards and hold it in place.
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. While holding the lock in place, slide the battery out towards you.
    • While holding the lock in place, slide the battery out towards you.
  3. Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Use a plastic opening tool to pry off the plastic panel above the keyboard.
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  6. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  7. Slowly lift the keyboard out, up and towards the screen.
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  8. Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  9. Remove stickers from four corners of laptop. Remove screws underneath stickers.
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  10. Use plastic opening tool to pry the hinges off. Remove the screen cover.
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
  11. Remove cable located next to the fan. Fold down screen without screen back cover to remove cable as shown.
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  12. Unscrew both screws on each side of the screen. Remove the screen.
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
Conclusión
Una persona más ha completado esta guía.
Equipo
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,942
