Saltar al contenido principal
Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
Qué necesitas
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: paso 1, imagen 1 de 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: paso 1, imagen 2 de 3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: paso 1, imagen 3 de 3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 2, imagen 2 de 2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 3, imagen 1 de 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 3, imagen 2 de 2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 4, imagen 1 de 2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: paso 4, imagen 2 de 2
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Conclusión
Una persona más ha completado esta guía.
Robby
Miembro Desde 02/04/13
52 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 7-7, Maness Winter 2013 Miembro de Cal Poly, Team 7-7, Maness Winter 2013
CPSU-MANESS-W13S7G7
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 2,577
