Introducción
This guide will assist you in removing the display of your device. You'll need to be extra careful when removing the glass screen from your device.
Qué necesitas
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
2 personas más completaron esta guía.
