Saltar al contenido principal
Introducción
This guide will help you to remove your broken RAM and replace it with a new one. Since the RAM is frequently updated to ensure top performance, the RAM is very easy to replace.
  1. Make sure you turn the laptop off first. Close the laptop lid and flip it over so that Toshiba logo is facing down. Close the laptop lid and flip it over so that Toshiba logo is facing down.
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver. Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer.
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver. Use the plastic opening tool to remove the back cover from the laptop. Be aware that static discharge can cause damage to sensitive electrical components within the computer.  To avoid this you can wear an anti-static wrist strap.
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. This laptop does not have a RAM present. Follow instructions to replace your own. Evenly press down on the clips on either side of the RAM stick. To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Conclusión
Una persona más ha completado esta guía.
Equipo
Un Comentario
I’ve got this exact model. Stock 6GB of RAM. However, I’ve attempted to upgrade to 8GB and have tried multiple sticks of RAM and no matter what, the computer won’t recognize it. I’ve ensured it’s locked in properly, RAM is functional, even factory reset. All to no success. Any ideas?
Steve B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 236
