Saltar al contenido principal
Toshiba Satellite L55t-B5271 RAM Replacement
Qué necesitas
  1. Toshiba Satellite L55t-B5271 RAM Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 RAM Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L55t-B5271 RAM Replacement: paso 2, imagen 2 de 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 RAM Replacement: paso 3, imagen 1 de 3 Toshiba Satellite L55t-B5271 RAM Replacement: paso 3, imagen 2 de 3 Toshiba Satellite L55t-B5271 RAM Replacement: paso 3, imagen 3 de 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: paso 4, imagen 1 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: paso 4, imagen 2 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 RAM Replacement, RAM: paso 5, imagen 1 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: paso 5, imagen 2 de 3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: paso 5, imagen 3 de 3
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Conclusión
Una persona más ha completado esta guía.
Equipo
Un comentario
I’ve got this exact model. Stock 6GB of RAM. However, I’ve attempted to upgrade to 8GB and have tried multiple sticks of RAM and no matter what, the computer won’t recognize it. I’ve ensured it’s locked in properly, RAM is functional, even factory reset. All to no success. Any ideas?
Steve B - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 389
