Introducción
This guide will help you replace a broken motherboard in your laptop. It is a detailed process but this guide will allow you to easily remove and replace your motherboard.
Qué necesitas
Herramienta utilizada en este paso:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Evenly press down on the clips on either side of the RAM stick.
To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
Disconnect all of the ribbons by lifting the tabs and gently pulling them out.
Una persona más ha completado esta guía.
