Saltar al contenido principal
Toshiba Satellite L55t-B5271 CD Drive Replacement
Qué necesitas
  1. Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: paso 1, imagen 1 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: paso 1, imagen 2 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 2, imagen 1 de 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 2, imagen 2 de 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 3, imagen 1 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 3, imagen 2 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 3, imagen 3 de 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: paso 4, imagen 1 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: paso 4, imagen 2 de 3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: paso 5, imagen 1 de 2 Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: paso 5, imagen 2 de 2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  6. Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 6, imagen 1 de 2 Toshiba Satellite L55t-B5271  CD Drive Replacement: paso 6, imagen 2 de 2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 268
