Saltar al contenido principal
Toshiba Satellite L55W-C5256 CPU Heatsink Replacement
Qué necesitas
  1. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, Battery: paso 1, imagen 1 de 1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 3, imagen 1 de 1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 4, imagen 1 de 1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 5, imagen 1 de 1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 6, imagen 1 de 1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, CPU Heatsink: paso 7, imagen 1 de 1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 8, imagen 1 de 1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 9, imagen 1 de 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 9, imagen 2 de 3 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: paso 9, imagen 3 de 3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 175
