Introducción
Use this guide to replace your RAM.
If you are experiencing memory issues or your computer struggles to run some programs, then you should use this.
The process is simple and requires only removing one screw.
Qué necesitas
Flip the computer over so that the bottom is facing up.
Slide right switch above the battery so that it is in the rightwards position.
Place the laptop upside down so the bottom is facing up and the side that opens is facing you.
In the middle of the laptop there is a panel held down by one 6 mm screw, remove that screw using a Phillips #0 screwdriver.
Remove the RAM cover.
Una persona más ha completado esta guía.
