Saltar al contenido principal
Toshiba Satellite L505D-GS6000 Key Replacement
Qué necesitas
  1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: paso 1, imagen 1 de 3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: paso 1, imagen 2 de 3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: paso 1, imagen 3 de 3
    • Open laptop in the front facing position.
    • Use a plastic opening tool to remove the desired key from the keyboard.
    • When lifting up on the key, do so carefully as to not break the key or its housing underneath.
  2. Toshiba Satellite L505D-GS6000 Key Replacement: paso 2, imagen 1 de 1
    • Use a finger to push a new key into place.
Conclusión
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
Adam Dellicker
Miembro Desde 03/19/18
539 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 439
